Results 16 to 30 of 47
05-17-2011, 01:03 AM #16
I don't know why so many people give that artic compound a bad rap. I had similar results when i did my system with it. it may no be the best out there, but for the price you can't beat the performance
The path to universal understanding starts here: Say what you mean, and mean what you say.
05-17-2011, 01:05 AM #17
wow, pretty nice improvement just for changing the pads.
Main System (X79 Beast):
Intel Core i7-3960X @ 4.6GHz | ASUS P9X79 WS | Kingston HyperX Genesis 32GB (8x4GB) DDR3 1600MHz Memory Kit | Nvidia GeForce GTX 690 (Main Card) | GIGABYTE GeForce GTX 650 Ti OC 2GB (Dedicated PhysX card) | ASUS Xonar Xense Audio Card | NZXT Phantom 820 Case | CM Silent Pro Gold 1200W PSU | 2 x Kingston HyperX 240GB 3K SSDs in RAID 0 | 2x WD RE3 1TB Hard Drives | WD Caviar Blue 500GB Hard Drive (Back-up Storage) | Noctua NH-D14 CPU Cooler | Windows 8 Pro
Test Bench (X79 System):
Intel Core i7-3820 @ 4.6Ghz | ASUS Rampage IV Extreme | Kingston HyperX 16GB DDR3 2133MHz Memory Kit | XFX HD7870 | Aerocool Striker-X Air test bench | Rosewill Lightning 1300W | LSI 3ware 9750-8i SAS+SATA RAID Card | Kingston HyperX 240GB 5K SSD | Seagate 500GB Hard Drive | Thermaltake Frio OCK CPU Cooler | Windows 8 Pro
Laptop (Macbook Pro):
Intel Core i7-2720QM @ 2.2GHz (3.3GHz Turbo) | Kingston HyperX 16GB 1600MHz DDR3 | AMD Radeon HD 6750M 1GB (Dedicated Video Card) | Intel HD Graphics 3000 512MB (Integrated) | Zalman N128GB SSD | Hitachi 500GB 7200 RPM Hard Drive | Mac OS X 10.8.2
05-17-2011, 01:17 AM #18
The GSO already had what looked like similar pads to the ones I got (good job EVGA) just thinner ones and they were in pretty good shape so I only replaced the GPU's TIM which was pretty old. On the 285 GTX the mosfets had some kind of fabric pad with white ceramic like stuff that was all falling off so I put the new pads in there. I imagine the pads where a bit thick at first and the GPU had no good contact with the TIM i put on there so I had to remove the whole thing again and that was the case that the material was not making good contact with the heatsink. I added more TIM and that seemed to do the trick althou I must have not done a very good job becauce the temps on the GTX are 1-2C higher. I plan to put a big piece of the Pad I got for the mosfets on the GPU to see how it does. As you can see the 480 GTX had nothing done on it, has best air flow of all in case and is still running hot (well hot in my opinion).
Setup:#1 Intel i7 2600k @ 4.7 GHz, Mobo: ASUS P8P67 Deluxe B3, Memory: Gskill Ripjaws 2133 2x4GB
Video card: Gigabyte 480GTX , PSU: Ultra X3 1600W, HD: OCZ Vertex 4 120GB & 1x160GB WD, OS: Windows 7 64-bit Premium,LG 4x Blueray drive, Monitor: Samsung 1ms TOC 27", Case: AZZA Solano 1000, Liquid cooling: Dual + Triple Swiftech ratiator stacked, Apogee XT block & Thermaltake P400 pump + res.
05-17-2011, 01:19 AM #19
05-17-2011, 01:29 AM #20
What are your case temps? I'm running two GTX 580s in a case that does not have any side ventilation, and I just have a single fan blowing into the whole case, but three fans blowing out. I experience hot air coming from the PC when gaming, but during just normal use on a normal day it is just slightly warm. I'd say as long as nothing gets to the point where it is hard to touch due to being too hot (except for the video card) then you should be fine. If any of the heatsinks in your system gets really hot where it burns you, then you might need additional cooling. With my setup, it gets to the point where it is hot, but not so hot where it would burn my fingers.
Of course heat kills over time, but all of the chipsets that are running on the system are tested at 85C+ and if they don't pass the tests, they cannot be sold, so even if the chipset seems to be running at 60C - 65C ( X58 ), depending on which motherboard you are running, around 40-50C on P67, then you should be just fine. As long as your 2600K is within 70-75C it should be fine, though I like to run mine around 65-70C at higher clock speeds, like yours.Main System (X79 Beast):
05-18-2011, 02:22 AM #21
I havent really looked at my case temps but that probablly because everything pretty much feels pretty cool to the touch. I have an Azza Solano casse with 3 140mm front fans, one at back, huge side and top fan plus 2 fan mountings at bottom. When all the gpus are folding they do raise the temps a bit, even the cpu's temp jump up a notch but nothing dramatic. I like to keep most of my hardware under 75, over 70 I consider hot. I dont have the pics with me but I did replace the thermal compound on the 285 GTX with the thermal pad and to my disapointment the temps went up to 80 when folding. The GPU is huge so I ended up wasting alot of TIM on it, and I was finally able to get it to run at 69 with an moderate application of some left over shin-etsu.
05-18-2011, 01:24 PM #22
Like I said before, you can always try the IC7 TIM I was recommending. I'm pretty sure it'll give you a decent 2-4 degrees.
Sent from my Samsung Galaxy S II using TapatalkIntel Core 2 Quad Q6600 (G0) @3.4GHz (8 x 425)
Gigabyte HD6950 2GB @HD6970 (Unlocked Shaders and Clocks
05-18-2011, 06:00 PM #23
05-19-2011, 04:30 PM #24
if nothing else you can do like i did and lower the ambient temp in the room, I keep mine at 68 F.
06-28-2011, 02:53 AM #25
Junior Member
- Jun 2011
- 26 Minutes 34 Seconds
i ordered some fujipoly 6.0W/mK at 1.5mm, but some people are suggesting it will cause problems with the mosfet/gpu making contact with the HSF on a Radeon HD 6970...
(long story short... i went to change out TIM on my 6970s and discovered some of the ram thermal pads were damaged and attempted to use arctic silver ceramique as a replacement, but my temps went up...)
do you think the 1.5mm thickness will still be acceptable in a 6970?
06-28-2011, 09:13 PM #26
I think they'll be just fine for your 6970. But if you're uncertain you can always lay one layer of pads over the chips and re-attach the heatsink and then remove the heatsink again and see if the pads got squeezed a little. If so, then you have good contact. If not, you can always use 2 layers of pads, preffered with a good thermal compound/paste between the two pads.
GOOD LUCK!
06-28-2011, 11:27 PM #27
well I can say that for my 9600 gso's and 285 gtx the 1.5 was a tad thick. When the pads on the mosfets are thick then the heatsink does not make too good of a contact with the gpu, thus you either get higher temps or have to use alot of thermal paste. I also smeared on some ceramic compound for better contact.
06-29-2011, 01:15 AM #28
As I understand it the pads melt then resolidify over and over, which is why old ones are around the die rather than on it when they get old. if yoou get it hot then tighen it a smidge it shouold improve the contact.
06-29-2011, 02:38 PM #29
I have had some great results with Antec Formula 7 on GPU's and CPU's.
RIG:i7-3770k @4.6Ghz/ASUS P8Z77 Deluxe/GSkill DDR3-2400/2xHD7970/Vertex 4/SSonic Plat 1000/H100/HAF XB
Laptop: i7-3630/ 16GB (4x4) DDR3-1600/ HM77/ GTX 675MX@1050Mhz/ 128GB SSD/ 256GB Vector SSD/ 17in Matte/ Steel Series Keyboard/ Killer Networks/ 1080p
SERVER: E3-1240V2/TYAN S5512/Kingston DDR3-1600 ECC/LSI Mega9260-4i w/2xVertex4 256GB RAID0(VMFS Datastore)/Vertex3(System)/X650 SSonic Gold/ESXi 5.1
06-29-2011, 06:46 PM #30
Achievements:
- Jun 2011
- 3 Days 1 Hour 54 Minutes 53 Seconds
Yeap dont forget http://www.newegg.com/Product/Produc...-080-_-Product
Is the stuff Asetek uses pretty much on their cpu coolers for the antec/corsair and their ALC's like the h70h/h60/920/620 ect.
Ram replacement question
By dumdum in forum Motherboards, CPUs, & MemoryReplies: 3Last Post: 11-13-2012, 07:41 PM -
Replacement for two 470’s in SLI
By Pablo 54 in forum Video & AudioReplies: 30Last Post: 11-06-2012, 06:40 AM -
Sony’s Thermal Conductive Sheet Expected to Replace Thermal Grease — Tech-On!
By RSS_Poster in forum NewsReplies: 0Last Post: 07-22-2012, 04:49 AM -
Thermal take gear being given away on APH FB page
By Blacksmith1 in forum Member NewsReplies: 1Last Post: 11-22-2011, 12:28 PM -
Saturn Horn replacement
By slugbug in forum Car TalkReplies: 8Last Post: 07-28-2011, 10:20 PM
