Results 16 to 20 of 20
06-02-2011, 03:38 AM #16
what i want is to to know how you typed all that so fast.
no really, all i want is to use an led as a power on indicator. i want it to last. but i think I figureout a way to do this with no modifications. since the 24 pin connector only has 2 pins in it ATM to tell it turn on/off then the 3.3 volt pin is open. so I'll just connect to that.
I think that should work fine. if not I'll just raid a few more old cases for the lights till i figure it out.The path to universal understanding starts here: Say what you mean, and mean what you say.
06-02-2011, 03:53 AM #17
if it is a blue or white LED it might last for a while the red/green/amber/orange/yellow LEDs not so much. The blue/white/aqua colors require anywhere from 2.6-3 volts to operate, the others are like in the 1.5-2 voltage range I have to wait for my roommate to get off the XCrack 360 to verify this.
Mini Me...
Is back in action.
Intel Core i7 970 @ 4.2GHz
Crucial Ballistx 1333Mhz 7-7-7-20
Heatkiller CPU
XSPC Quad 120mm rad (Loop1)
2x AMD 6970 Crossfire
Koolance 697 (Loop 2)
Swiftech Tri 120mm Rad (Loop2)
x 3 24" 1920x1080 Monitors
PC Power and Cooling 950 Watt PSU
Creative X-FI Fatality Pro
ASUS Rampage 2 Extreme
06-02-2011, 04:11 AM #18
frozen cpu sell them in all colors at 3.3 volts. the copy of "getting started in electronics" from radio shack, that I just pulled off the shelf give a voltage range for each color. none of which is over 3.0 volts. it does however give a formula for getting them to work by using a resistor. and uses 5.0 volts a the referance point in the example.
series resistance = supply volts - led voltage / led current. so what i need to figure out is how many milli amps my led needs as the led current.
the example states 5v - 1.7v /0.01 (10 milliamps) =330 ohms
so with a few extras and some playing around i should be able to get a stable led functioning. i have a bunch of red ones here but they are 3mm, and the mounts i stole from the case are 5mm but i can use them to test with i guess.The path to universal understanding starts here: Say what you mean, and mean what you say.
06-04-2011, 08:14 PM #19
good luck.
Mini Me...
Is back in action.
Heatkiller CPU
06-04-2011, 09:09 PM #20
found a better way....
112_0800.jpg as soon as i can get some batteries I'll take a better pic of it. but that TT emblem is my "the power is on" indicator.The path to universal understanding starts here: Say what you mean, and mean what you say.
Manually Setting Your Memory Timings and Voltage!!
By xfxsupport in forum XFX Motherboards, North America OnlyReplies: 25Last Post: 09-02-2009, 04:42 PM
