Klar Running temps.
Results 1 to 13 of 13
Thread: Running temps.
    May 2009
    Sunny S. Fl, U.S.A.
    2 Weeks 4 Days 1 Hour 20 Minutes 33 Seconds
    Default Running temps.
    I got the 560 installed and folding. I thought these theings were supposed to be cooler than the 200 series???
    At stock clocks it runs 95c, at an O/C it was over 100c and my case is no hotter than it has been for months, cooler actually by 2-3c.(from 111 f to 107 f).
    560new.gif I'm a little worried cause the F@H client has already crashed once on this thing.
    The path to universal understanding starts here: Say what you mean, and mean what you say.
    Nov 2006
    18 Hours 32 Minutes 10 Seconds
    YIKES.... hmm get an aftermarket cooler, or make sure you have plenty of ventilation over the intake of the card.
    Mini Me...
    Is back in action.
    Intel Core i7 970 @ 4.2GHz
    Crucial Ballistx 1333Mhz 7-7-7-20
    Heatkiller CPU
    XSPC Quad 120mm rad (Loop1)
    2x AMD 6970 Crossfire
    Koolance 697 (Loop 2)
    Swiftech Tri 120mm Rad (Loop2)
    x 3 24" 1920x1080 Monitors
    PC Power and Cooling 950 Watt PSU
    Creative X-FI Fatality Pro
    ASUS Rampage 2 Extreme
    Quote Originally Posted by Blacksmith1 View Post
    Version of "Dragon's Guide to OverClocking",
    step 1 find fire extinguisher
    step 2 turn up the settings
    step 3 Pray !!!
  3. #3
    May 2009
    Sunny S. Fl, U.S.A.
    dude this thig has a dual fan H/S on it. and now i'm even more worried after reading this
    http://www.neoseeker.com/Articles/Ha...TX_560/18.html
    my idle temps are 13-14c above what they are talking about. on the SAME card. I'm gonna get ahold of gigabyte tommorow and see if reseating my H/S with new TIM will void the warrenty. if so, they will be getting the card back.
  4. #4
    May 2011
    Lake Worth, FL
    1 Week 1 Day 12 Hours 13 Minutes 31 Seconds
    Should not void the warrante. Use Antec F7. Good Stuff!
    RIG:i7-3770k @4.6Ghz/ASUS P8Z77 Deluxe/GSkill DDR3-2400/2xHD7970/Vertex 4/SSonic Plat 1000/H100/HAF XB
    Laptop: i7-3630/ 16GB (4x4) DDR3-1600/ HM77/ GTX 675MX@1050Mhz/ 128GB SSD/ 256GB Vector SSD/ 17in Matte/ Steel Series Keyboard/ Killer Networks/ 1080p
    SERVER: E3-1240V2/TYAN S5512/Kingston DDR3-1600 ECC/LSI Mega9260-4i w/2xVertex4 256GB RAID0(VMFS Datastore)/Vertex3(System)/X650 SSonic Gold/ESXi 5.1
  5. #5
    May 2009
    Sunny S. Fl, U.S.A.
    I'll use what I got which is the arctic ceramique.
  6. #6
    Feb 2011
    Perris CA
    6 Days 7 Hours 7 Minutes
    that seems really high my 560Ti idles at 30c and GPU-z reports my fan rus at 1740 RPM's @ 40%
    Quote Originally Posted by Cody_Irwin View Post
    My buttox feels like its been man handled.
  7. #7
    May 2009
    Sunny S. Fl, U.S.A.
    I got a feeling I'm gonna be stuck with a card that runs hot.
    start at the bottom and work up.
    Michael Peters [ sflblacksmith@yahoo.com ]Sent : 7/15/2011 10:06Question : this card is supposed to be SLI capable, It will be run in a case with other cards.. It is runn far too hot for what has been reported as "normal" for this GPU My nome was 24. deg C when I came home and this card was well over 100 C I have been running
    1 GTX280 O/C'd Folding
    1 GTX260 O/C'd folding
    and 1 9800gx2 O/C folding
    in this case and none of them has passed 80 C. the case has 3 120mm intake fans, 2 120mm exaust fans, and the PSU pulling air out. there is more than enough air flow.
    this card is supposed to run cooler than they do and runs hotter at stock clocks. too hot to use full time folding. there persons on the forum I attend have similar cards and run far cooler at higher ambient temps.
    Answer - 1105458
    Answer : Dear Customer,
    at default spec is within range, on a full load is slightly high but is still acceptable.
    Do make sure that you have good cooling on your system and only test with just one card installed.
    Question - 1105458
    From : Michael Peters [ sflblacksmith@yahoo.com ]Sent : 7/14/2011 01:24Question : I seem to be having a cooling problem. this card is reported to idle in the 30-40c range. It is idling at 50c. the ambient temp on the room is 21c, the highest temp in my case is 42c. and that is nowhere near the card. there are three intake fans brining air into the lower region of this case.
    under full load running the Stanford Folding @ Home app the 560 hits 95c on stock clocks. with a mild O/C it hit 100c in less than a minute, at which point I shut it down and restored the clocks.
    from what I see on the web these temps are far higher than I should reasonably expect.
    will it void the warrenty if I remove the HSF assembly and reset it with new TIM?
    the the GTX 200 series cards that have been in there do not run this hot at load. the 9800gx2 in there doesn't run that hot either.
    Attached is a GPU-z screenshot showing the clocks, and usage. let me knoiw if there is any other information you need.
    Model Name : GV-N56GOC-1GI
    PCB ver :
    Driver Ver : 6.14.12.7533
    Serial No. : 111901067832
    Purchase Dealer : Gigabyte
    Motherboard Brand : Asus
    Model : M3N-HT deluxe
    Operation System : Win XP SP : 3
    PSU: antec true power trio 550
    CPU:Phenom II 9500
    Guess I shold proofread my submissions to them...
  8. #8
    May 2009
    Sunny S. Fl, U.S.A.
    Solved. i got to thinking, what if running by itself the card ran cooler, that wouldn't help me much but it would solve the over heat. so I got to looking at the setup and realized it was pulling the heat straight off the back of the 280's gpu without enough room to get cool air. if you run one of these in SLI with a full cover reference card, put this one on the bottom. the plastic cover will come too close to these fans to allow them to work. and without that cover on it this card allows more room for the reference design to pull airflow if the reference card is on top, than it would over another reference card. is that too confusing?
    any way check this out.
    560fixed.gif I'm bumping it up till it either EUE's or overheats. trying to get 10K or more PPD from it.
  9. #9
    Feb 2011
    Perris CA
    nice I didn't even think about all your extra cards ya have in your case
  10. #10
    May 2009
    Sunny S. Fl, U.S.A.
    I gotta say I am impressed with the response time to my ticket. alot faster than XFX ever was. and the guy(s) was/were very professional in their attitude.
    As soon as iget a couple days folding with no errors I'll add this puppy to the list.
  11. #11
    Glad you found the culprit and solved the problem.
    Sent from my Samsung Galaxy S II using Tapatalk
  12. #12
    Aug 2006
    Euless, Texas
    1 Week 1 Day 19 Hours 5 Minutes 48 Seconds
    Glad you fixed the problem. Was gonna say OCed my 465's don't go over 80C and your 560 should be running alot cooler than my cards and 280s. 280s where hot beasts. (wish I still had mine)
    Univac
    Intel Core i7 3960x @ 4.6GHz | ASRock Extreme 6 x79 | 64GB Kingston HyperX Beast 2133 | GTX 580 SLI |120GB Corsair Neutron GTX | Cooler Master HAF 922 | Custom water loop | Corsair HX850w | Windows 8 Pro MCE x64 | Samsung GS2 Shostock 2 | InFocus 1080p DLP Projector 120" | 24" NEC MultiSync 2470WNX | Logitech G930 | JBL Creature 2 2.1
  13. #13
    May 2009
    Sunny S. Fl, U.S.A.
    the 560 is running fine, O/C @ 925/1850 mem@ 1054, 94-99% gpu load, 80c. the A/C is acting up a bit so the house is at 21.5c instead of the normal 20c. my case shows 40c at the hottest point. since this card can handle 100c (or so they said) I'm gonna call 80c good to go.
  1. Fixing Ivy Bridge CPU temps: IHS removal (DIY)
    By najiro in forum Motherboards, CPUs, & Memory
    Last Post: 11-07-2012, 09:45 PM
  2. GTS250 running half speed...
    By sifter in forum Video & Audio
    Last Post: 06-29-2011, 01:20 AM
  3. GPU temps are high, kinda
    By a1namill in forum XFX NVIDIA Graphics Cards, North America Only
    Last Post: 06-10-2011, 08:33 PM
