Klar Phenom II X1090T fan making tons of noise
Results 1 to 15 of 15
    Oct 2009
    1 Day 17 Hours 18 Minutes 25 Seconds
    Default Phenom II X1090T fan making tons of noise
    I just installed my new Phenom II X6 1090T. It's the first CPU I installed in a while. Perhaps the last one was the Celeron 300A, and that came on a card. Anyway, seemed simple enough, especially after watching a YouTube video (and the start of another which luckily reminded me to upgrade the BIOS). Of course, I have no idea if I did everything correctly, but the PC at least works.
    Problem is the fan noise. It's just terrible. I ran Overdrive and it says that FAN0, which I guess is the CPU fan, is running at around 5400rpm. Temperature is 51C for that fan (room temperature is 32C). CPU usage is at around 17%, which isn't idle, but it's not even close to load. Cool & Quiet is enabled.
    So the first question is, did I do anything wrong? Did I mess up the thermal paste by moving it, dust got in the way, that kind of thing. I mean, is it normal temperature to be 19C over room temp with a slight load?
    Second is, is it possible to undervolt the non-load voltage? I underclocked and undervolted in Overdrive, but that only reduces the voltage when the cores are at max. Most of the time they're at 2400MHz and voltage goes to 1.325, which is more than I set.
    It's a real pity that I can't just put the old CPU back in, because I'll need to reapply thermal past which I don't have.
    Anyway I guess I'll start looking for aftermarket coolers. Never used them, but this noise is completely driving me nuts.
    May 2009
    Sunny S. Fl, U.S.A.
    2 Weeks 4 Days 1 Hour 20 Minutes 33 Seconds
    At full rev stock amd fans tend to be a bit noisey. but 5400 about right for rpm. as for the noise I can't hear your fan to tell you if it's louder than it should be.
    The path to universal understanding starts here: Say what you mean, and mean what you say.
  3. #3
    Apr 2011
    West Lafayette, IN USA
    1 Day 13 Hours 8 Minutes 56 Seconds
    Any fan, running at 100% makes a bit of noise, more so GPU and CPU fans. Some boards can automatically adjust CPU fan speeds as needed. As far as the temps..for a cpu it depends on your cpu. my Athlon X2 4600+ runs at about that, under 100% load. Maybe that is a bit high if the CPU doesn't have much load.
  4. #4
    May 2009
    Sunny S. Fl, U.S.A.
    My room is 22c my cpu at idle is 34-35c. that's with the system sitting with only IE running. that's a 12-13 c difference and my old aluminum only cooler ran hotter. your room is hot, the system is going to run hot. a better HSF will help but cooling the room it's in will help more.
  5. #5
    Oct 2009
    I think I'll order a low end cooler, probably the CoolerMaster Hyper TX3, which is in stock at ZigZag2000. If I had an idea of the noise I would have ordered a cooler from Amazon when I ordered the CPU, and would have had more choice and lower prices. Still, hopefully even a low end cooler will be better than the stock cooler.
    I just didn't imagine another cooler would be needed because the Phenom II 710's cooler was a lot quieter.
    Edit: Might go for another cooler. There are local stores so would depend on what's in stock. I really want to get this replaced quickly.
  6. #6
    Nov 2006
    18 Hours 32 Minutes 10 Seconds
    I agree with Black, you may want to drop your ambient temps by a lot. if your ambient going to be that high I suggest you get a really good cooler.
    Mini Me...
    Is back in action.
    Intel Core i7 970 @ 4.2GHz
    Crucial Ballistx 1333Mhz 7-7-7-20
    Heatkiller CPU
    XSPC Quad 120mm rad (Loop1)
    2x AMD 6970 Crossfire
    Koolance 697 (Loop 2)
    Swiftech Tri 120mm Rad (Loop2)
    x 3 24" 1920x1080 Monitors
    PC Power and Cooling 950 Watt PSU
    Creative X-FI Fatality Pro
    ASUS Rampage 2 Extreme
    Quote Originally Posted by Blacksmith1 View Post
    Version of "Dragon's Guide to OverClocking",
    step 1 find fire extinguisher
    step 2 turn up the settings
    step 3 Pray !!!
  7. #7
    Oct 2009
    Dropping the ambient temperature may be a solution, but it's like killing a mosquito with a nuclear missile. I've had PC's working in these temperatures for years, and never had problems with fan noise. Granted, the 1090T has a high TDP, but it's not as if I'll be stressing it most of the time. All I need is a cooler which will make less noise, or at least less noise at low load. I think (or rather, hope) that a low end cooler would be enough for this.
  8. #8
    May 2009
    Sunny S. Fl, U.S.A.
    get a heat pipe cooler, something known to work, the price doesn't always mean better, some companies will charge more for the same perfomance because they can.
  9. #9
    May 2011
    Lake Worth, FL
    1 Week 1 Day 12 Hours 15 Minutes 21 Seconds
    ET look at the A50 by Corsair on newegg. I have one on my OC'ed i5-760 and it keeps it super cool with almost no noise. Cant hear it over the vid cards.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835181012
    I
    ts less than 19.00 after rebate and free shipping.
    RIG:i7-3770k @4.6Ghz/ASUS P8Z77 Deluxe/GSkill DDR3-2400/2xHD7970/Vertex 4/SSonic Plat 1000/H100/HAF XB
    Laptop: i7-3630/ 16GB (4x4) DDR3-1600/ HM77/ GTX 675MX@1050Mhz/ 128GB SSD/ 256GB Vector SSD/ 17in Matte/ Steel Series Keyboard/ Killer Networks/ 1080p
    SERVER: E3-1240V2/TYAN S5512/Kingston DDR3-1600 ECC/LSI Mega9260-4i w/2xVertex4 256GB RAID0(VMFS Datastore)/Vertex3(System)/X650 SSonic Gold/ESXi 5.1
  10. #10
    Oct 2009
    Joshua, the A50 is Intel only. Besides, I'm limited to what's available here in Israel. I ended up ordering the Hyper TX3. I should get it in the next day or two. Hopefully it will be good enough. I'm sure that at the very least it will be better than the stock cooler.
  11. #11
    May 2011
    Lake Worth, FL
    I am so sorry I ment the A70. I should pay more attention to my page links. 26.00USD
  12. #12
    Oct 2009
    Ah, thanks. Too late, but there's actually a local store that sells it. Costs about $57, which isn't that bad. The Hyper TX3 cost me $41 including shipping, but I was willing to pay more to have it sent by courier, so I don't have to leave home to take it. I'm also a little worried that the A70 will be too big for my case. It's rather narrow (under 19cm), so the slightly smaller TX3 is safer (and I'll still be worried even about it until I get it).
  13. #13
    May 2011
    Lake Worth, FL
    I looked at the TX3 you should be good with that. If not you could change the fan and get better noice/performance ratio.
  14. #14
    Oct 2009
    Definitely a big improvement. Not completely silent at load, but quieter at load than the stock cooler is at idle. It's definitely bearable at load so I can run the folding test I wanted without feeling like a jet is taking off inside my house. Cores are currently at 57-58C (ambient 31C) folding on six cores at stock speed.
  15. #15
    May 2009
    Sunny S. Fl, U.S.A.
    Can't complain about that.
  1. WTB Phenom 2
    By PP Mguire in forum Classifieds
    Last Post: 02-19-2012, 08:10 PM
  2. EK-FC7950 in the making
    Last Post: 02-11-2012, 01:25 AM
  3. Replies: 0
    Last Post: 08-20-2011, 05:11 AM
  4. SLI Tests: Intel Sandy Bridge vs AMD Phenom II
    By RSS_Poster in forum Product Reviews & Discussion
    Last Post: 06-27-2011, 01:06 PM
  5. Upgrade stock Phenom II 710 to 1090T?
    By ET3D in forum Motherboards, CPUs, & Memory
    Last Post: 06-27-2011, 08:21 AM
