Klar Fixing Ivy Bridge CPU temps: IHS removal (DIY)
Results 1 to 14 of 14
    Nov 2012
    Philippines
    6 Days 18 Hours 32 Minutes 41 Seconds
    Default Fixing Ivy Bridge CPU temps: IHS removal (DIY)
    Hi!
    I'm new here and I just wanted to start sharing interesting stuff.
    I found something interesting the other day.
    A video about replacing the stock thermal compound used in ivy bridge processors which is currently blamed for the heat issues these processors have.
    It did gave interesting results:
    Pros: Lowered temperatures, better overclocking capabilities
    Cons: Will void warranties
    ivy processor users might want to try this.
  2. Thanks peti1212 thanked for this post.
    Like peti1212 liked this post.
  3. #2
    Aug 2006
    Euless, Texas
    1 Week 1 Day 20 Hours 20 Minutes
    This is pretty well known to those that have the testes enough to do it. It doesn't warrant clocks that are that much higher though as Ivy still runs warmer natively than Sandy.
    Univac
    Intel Core i7 3960x @ 4.6GHz | ASRock Extreme 6 x79 | 64GB Kingston HyperX Beast 2133 | GTX 580 SLI |120GB Corsair Neutron GTX | Cooler Master HAF 922 | Custom water loop | Corsair HX850w | Windows 8 Pro MCE x64 | Samsung GS2 Shostock 2 | InFocus 1080p DLP Projector 120" | 24" NEC MultiSync 2470WNX | Logitech G930 | JBL Creature 2 2.1
  4. #3
    peti1212's Avatar
    peti1212 is offline PR Manager/Review Manager Achievements:
    Three FriendsRecommendation Second ClassVeteranTagger Second Class10000 Experience Points
    Awards:
    Most Popular
    Nov 2006
    California
    5 Days 16 Hours 56 Minutes 37 Seconds
    I remember reading at Anandtech that some users replaced the TIM under the IHS and it didn't do anything to lower temperatures, or the difference was minimal. Some people did it even without the IHS. A lot of people ruined their warranties with no gain. Though I might be wrong. Interesting video najiro, thanks for sharing.
    Main System (X79 Beast):
    Intel Core i7-3960X @ 4.6GHz | ASUS P9X79 WS | Kingston HyperX Genesis 32GB (8x4GB) DDR3 1600MHz Memory Kit | Nvidia GeForce GTX 690 (Main Card) | GIGABYTE GeForce GTX 650 Ti OC 2GB (Dedicated PhysX card) | ASUS Xonar Xense Audio Card | NZXT Phantom 820 Case | CM Silent Pro Gold 1200W PSU | 2 x Kingston HyperX 240GB 3K SSDs in RAID 0 | 2x WD RE3 1TB Hard Drives | WD Caviar Blue 500GB Hard Drive (Back-up Storage) | Noctua NH-D14 CPU Cooler | Windows 8 Pro
    Test Bench (X79 System):
    Intel Core i7-3820 @ 4.6Ghz | ASUS Rampage IV Extreme | Kingston HyperX 16GB DDR3 2133MHz Memory Kit | XFX HD7870 | Aerocool Striker-X Air test bench | Rosewill Lightning 1300W | LSI 3ware 9750-8i SAS+SATA RAID Card | Kingston HyperX 240GB 5K SSD | Seagate 500GB Hard Drive | Thermaltake Frio OCK CPU Cooler | Windows 8 Pro
    Laptop (Macbook Pro):
    Intel Core i7-2720QM @ 2.2GHz (3.3GHz Turbo) | Kingston HyperX 16GB 1600MHz DDR3 | AMD Radeon HD 6750M 1GB (Dedicated Video Card) | Intel HD Graphics 3000 512MB (Integrated) | Zalman N128GB SSD | Hitachi 500GB 7200 RPM Hard Drive | Mac OS X 10.8.2
  5. #4
    Aug 2006
    Euless, Texas
    People to fail to realize that Sandy is made the same way. Ivy is just a hotter chip due to the new tech.
    Univac
  6. #5
    Ivy is hotter because all of transistors are compacted into a smaller die when compared to Sandy.
  7. #6
    Aug 2006
    Euless, Texas
    The shrink usually leads to less TDP, more performance, and a cooler chip. The 3d transistors are what does it. I bet IB-E will be hotter than SB-E as well for the same reason. It's why taking the IHS off doesn't do much.
    Univac
  8. #7
    Nov 2012
    Philippines
    Quote Originally Posted by peti1212 View Post
    yeah that's the worst thing that could happen. I was wondering of the same thing of removing the IHS completely and mount the heat sink directly to the processor die. I remember pentium IIIs don't have IHS. I'm guessing in theory it should be cooler since it would be directly cooled by the cooler without the IHS right?
  9. #8
    Aug 2006
    Euless, Texas
    Yes it would be slightly cooler but you risk crushing the cores with too much pressure.
    Univac
  10. #9
    peti1212's Avatar
    Awards:
    Most Popular
    Nov 2006
    California
    Yep, you would have to come up with your own mounting mechanism because the socket mounting would not work anymore, because the socket bracket pushes on the IHS.
  11. #10
    Feb 2011
    Perris CA
    6 Days 7 Hours 11 Minutes 22 Seconds
    I would be too worried to do that with my CPU. $200+ for a new cpu would scare me too much. good luck to all that try this and hope it works for you.
    Quote Originally Posted by Cody_Irwin View Post
    My buttox feels like its been man handled.
  12. #11
    Feb 2011
    Crystal Lake, IL
    11 Hours 5 Minutes 57 Seconds
    Thanks for posting the video, and can honestly say that I would not attempt this. just to risky for me to consider.would have to agree similar to James86 in the above post best of " luck to all that try this and hope it works for you."
  13. Like CDsDontBurn liked this post.
  14. #12
    Nov 2012
    3 Hours 31 Minutes 50 Seconds
    interesting post, I wouldn't want to try it simply for the small performance gains. if you drop the price of a bricked processor (possible but if you're careful I suppose not a huge risk) into cooling upgrades and get air flowing correctly through your case that will yield more of a drop in temperature. I seem to have lowered temps either from switching my CM hyper 212 Evo from push to pull (single fan no push now), either that or additional case fans helped, or my thermal compound has broken in, if possible, like mentioned in this IHS removal thread:
    http://forums.anandtech.com/showthread.php?t=2260582
    Again it seems that thermal efficiency gains are close to insignificant. a better cooler and better fans, in my opinion, is a lot better spent and if you fry your processor overclocking (with intel's OC warranty!) you can just get a new one for $25 or however many pennies it is.
  15. #13
    Nov 2012
    wow I spoke too soon before seeing those temp changes, I didn't realize he had a core that was so much higher than the other two, thankfully my cores are quite even but if I had no warranty, and enough people had done this without damaging the core, I might just have to give it a try.
    I'd only worry about the tolerances changing without the IHS glue being there, there could be extra pressure on the CPU because of that. It could be a good thing, however...not sure how delicate it really is.
  16. #14
    Nov 2012
    48 Minutes 56 Seconds
    Thanks for sharing. I have herd of people doing this but the first time seen it done.
  17. Like najiro liked this post.
  1. Looking for Ivy Bridge Overclock guide
    By Buzzerbro in forum OverClockers Corner
    Last Post: 11-06-2012, 11:09 PM
  2. Want a list of Ivy-Bridge processors?
    Last Post: 11-29-2011, 02:26 AM
  3. Running temps.
    By Blacksmith1 in forum Video & Audio
    Last Post: 07-18-2011, 05:04 PM
  4. GPU temps are high, kinda
    By a1namill in forum XFX NVIDIA Graphics Cards, North America Only
    Last Post: 06-10-2011, 08:33 PM
  5. Fixing bad power boards?
    By Cody_Irwin in forum Off Topic
    Last Post: 06-04-2011, 10:54 PM
Tags for this Thread
