Klar Need some help
Results 1 to 14 of 14
Thread: Need some help
    Jul 2011
    5 Hours 55 Minutes 4 Seconds
    1 out of 1 members found this post helpful.
    Default Need some help
    Hey
    Just dropped in to ask if any of you guys would know what's Wong with my system. It's a new velocity micro pc. All the cables and everything are zip tied. I didn't mess around with anything inside the case.
    Before Christmas I had this issue that suddenly my would start giving problems on first boot. Then slowly the theme disappeared. And the desktop wouldn't respond. Then copy speed from partition to partition was around less than 1mb of speed. I reinstalled the system. It was working perfect once again. And once again now it's gone back to same. Only this time I can't install windows again using the oem recovery disk. It keeps giving me an error. And I formated my partition.
    The cd is scratch less. I even tried using the usb tool to write the installer from the disk to usb. And still the same error.
    I currently don't have the time to play around with it. I've got to study for my exam. It's day after. So maybe ill be able to get working on it around the end of this month.
    Aug 2006
    Euless, Texas
    1 Week 1 Day 20 Hours 5 Minutes 10 Seconds
    Try making a Windows 7 flash drive instead and try that. I would also check to see if the drive is still good and do a low level format on it. The slowness sounds like a nasty virus.
    Univac
    Intel Core i7 3960x @ 4.6GHz | ASRock Extreme 6 x79 | 64GB Kingston HyperX Beast 2133 | GTX 580 SLI |120GB Corsair Neutron GTX | Cooler Master HAF 922 | Custom water loop | Corsair HX850w | Windows 8 Pro MCE x64 | Samsung GS2 Shostock 2 | InFocus 1080p DLP Projector 120" | 24" NEC MultiSync 2470WNX | Logitech G930 | JBL Creature 2 2.1
  3. #3
    Dec 2007
    Michigan
    1 Day 4 Hours 6 Minutes 47 Seconds
    You could try unplugging and replugging the SATA cable/changing SATA cable, I've had that be an issue before.
  4. #4
    Jul 2011
    Will try the sata cable trick. But I got my exam tomorrow. I don't have the heart to see my computer not work and study at the same time.
    I can't format all the partitions as my data is on one of the partitions. The oem cables are zip tied to the chassis so it's not easy to pull out cables. They are exact fits.
    I'm not sure if it's a virus. Because the 2nd time I installed Windows it was fine. Until it was BSOD'ing after the Windows boot screen. I couldn't boot to safe mode to check the bsod error code.
    After my exams I'll try to do a bit of cleaning for dust between the cables also.
  5. #5
    Aug 2006
    Euless, Texas
    Quote Originally Posted by ryandigweed View Post
    If you catch my drift. Reinstalled it, it went away because it was fresh.
    Cables are easy, just cut the zip ties so you can move the cables. It wont harm anything, and if you want them to be zip tied later just buy a pack of them from Lowes. They are cheap.
    You don't have to format each partition to reinstall Windows. All you need to do is format the partition Windows is on. If some data is on there and you can't get it back then that's that anyways. Only other thing to do is take your drive out and stick it in another PC, virus/malware/spyware scan it, backup your data, then completely start from fresh.
    I'm starting to wonder if this is actually a wide spread virus because I have had 3 different people come to me with the same problem in the past week.
    Univac
  6. #6
    Jul 2011
    Yeah I was wondering the same too if there was anyone else facing this issue. I don't have another system to check it because I donated all my old hardware to a friend. But I'll try to work something out. I thought maybe something might have been wrong with he MBR. But now I'm beginning to think it could be the cables. At first I thought it was windows update. But this time It only installed a few updates. And after a week it went again. I don't download anything there. I only play games on steam. I hadn't even installed my photo shop softwares lol..
  7. #7
    May 2011
    Lake Worth, FL
    1 Week 1 Day 12 Hours 15 Minutes 3 Seconds
    Almost sounds like a rootkit virus. Try running TDSSKiller. Worth a shot.
    RIG:i7-3770k @4.6Ghz/ASUS P8Z77 Deluxe/GSkill DDR3-2400/2xHD7970/Vertex 4/SSonic Plat 1000/H100/HAF XB
    Laptop: i7-3630/ 16GB (4x4) DDR3-1600/ HM77/ GTX 675MX@1050Mhz/ 128GB SSD/ 256GB Vector SSD/ 17in Matte/ Steel Series Keyboard/ Killer Networks/ 1080p
    SERVER: E3-1240V2/TYAN S5512/Kingston DDR3-1600 ECC/LSI Mega9260-4i w/2xVertex4 256GB RAID0(VMFS Datastore)/Vertex3(System)/X650 SSonic Gold/ESXi 5.1
  8. #8
    Jul 2011
    Quote Originally Posted by Joshua_Mahr View Post
    Will give that a try when I get an OS onto this. Lol
  9. #9
    Aug 2006
    Euless, Texas
    Unlikely since you said you only played games, but have you had anything pop up saying Windows Security Plus 13 or anything like it?
    Univac
  10. #10
    Nov 2007
    Midwest
    2 Days 15 Hours 55 Minutes 10 Seconds
    How big is your HDD? I had an SSD do something like this last year: Would load, but could not update SP1. Then it would load intermittently then it just died.
    BBQ
    ASUS P8Z68-V PRO; i7 2600k @ 4.1GHz; Kingston HyperX 16 GB @ 1866; Mushkin Enhanced Callisto Deluxe 90GB SSD with Win7 Home Premium 64bit; OCZ Vertex 2 SATA II 2.5" SSD 60GB - Programs; 2 WD 2 TB Caviar Green RAID1; WD 2 TB Cavier Green in external USB3 case;EVGA FTW 670 GTX; Acer 22 inch Widescreen; PSU: Ultra 4x 1050
  11. #11
    Jul 2011
    It's a 1TB Hard drive.. Hittachi It's barely used.
    I think this could be the issue
  12. #12
    Aug 2006
    Euless, Texas
    Smart isn't always 100% accurate and I leave it disabled for that reason. Have Windows do a checkdisk scan on it. Let it do the reboot for the full scan.
    Univac
  13. #13
    Aug 2008
    SoCal
    4 Days 10 Hours 45 Minutes 49 Seconds
    Upon reading the OP, I immediately thought the drive was going out.
    "P180" Desktop | Built on, 2012-12-25
    3.4Ghz i5-3570k | Scythe SCSMZ-2100 92mm Samurai ZZ Rev.B | ASUS P8 Z77-V LK |Kingston HyperX 16GB CL9 RAM | PowerColor 7870 Myst Edition | 240GB Kingston HyperX SSD (OS) | 750GB 16MB SeaGate HDD (Storage) | 3x 320GB 16MB HDD in RAID-0 (Games) | Samsung 24x DVD-RW
    Laptop | Dell Latitude e6400 *Upgraded*
    p9500 | 4GB DDR2 PC6400 | NVIDIA Quadro 160M | 1440x900 Display | Kingston 128GB SSD | 250GB USB External HDD | 9-Cell Battery
    "Scottie" Desktop | Retired, 2012-12-20
    3.2Ghz p4 | ThermalRight sp-94 | 92mm Vantec Tornado | ABIT IC7-G | ThermalRight NB-1C | 2GB OCZ Platinum Ex 400Mhz 2-3-2-5 | PowerColor 4670 1GB AGP | 250GB 8Mb WD HDD (OS) | 320GB 16Mb WD HDD | 500GB 16MB SeaGate HDD | 16x LiteOn DVD-RW | LiteOn DVD/CD-RW combo drive
  14. #14
    Aug 2006
    Euless, Texas
    Quote Originally Posted by CDsDontBurn View Post
    Exactly my comment which happened to be first.
    Univac
