Klar Layer 2/3 help.
Results 1 to 2 of 2
Thread: Layer 2/3 help.
    Aug 2006
    Euless, Texas
    1 Week 1 Day 19 Hours 5 Minutes 48 Seconds
    Default Layer 2/3 help.
    I have a Foundry Fastiron Edge X424 that I pictured in the other thread. Right before the previous LAN I did 2 weeks ago I spent 2 hours trying to basically get it to work. This thing was setup for some serious **** (was at a Speakeasy Datacenter) and was locked down. I found a 1400+ page manual on the thing and managed to somehow soft reset it, add a new password to it, and then make it accept and forward DHCP to use at the LAN. This was all in terminal and now I want in the webgui. I have searched and cannot find anything that will help me get past the username and password for the gui. I was able to assign an IP but now it wont get to the web gui anymore with the IP/Gateway I assigned to it (had to manually set the other one).
    Not sure if anybody here knows layer 2/3 networking but I figured it was worth a shot.
    Univac
    Intel Core i7 3960x @ 4.6GHz | ASRock Extreme 6 x79 | 64GB Kingston HyperX Beast 2133 | GTX 580 SLI |120GB Corsair Neutron GTX | Cooler Master HAF 922 | Custom water loop | Corsair HX850w | Windows 8 Pro MCE x64 | Samsung GS2 Shostock 2 | InFocus 1080p DLP Projector 120" | 24" NEC MultiSync 2470WNX | Logitech G930 | JBL Creature 2 2.1
    Aug 2006
    Euless, Texas
    Nvm I figured it out.
    Univac
